looking for 12`s
looking for 12`s
This is the combination I am looking at putting together and I`m sure it will run
low 13`s but I am hoping it might hit high
12`s.Rebuilt 355 sbc with 10.5:1 compression,
dart sportman II heads,xe262 cam,wiend stealth intake,750 holley v.s.,shorty headers,dual high flow cats,dual exhaust,
3.73 gears,aubourne differential,th700r4
w/2400 stall converter,shift kit,msd ignition,accel coil,cowl induction hood,
3" k+n filter with xtreme lid.G60 Hoosier
tires.The car should wiegh about 3520lbs.
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Do yourself a favor and trash that Vaccum Secondary 750 and go with a 4150 double. They are much better carbs for performance applications.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
1987 GTA L98 MD8
My GTA
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Agreed with the VS carb. I also don't think the xe262 cam is enough for such a heavy car. The 700R4 isn't going to help much either. The low first gear creates too much of a gear spread between the 1-2 shift. You need to over-rev first gear so that when you shift to second you're not way below the power curve.
I'd guess with the current setup for a mid 13's. It'll really depend on traction.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
what about a camaro with a 355 carbed 750 DP with 400 horsepower and a turbo 350 with a b&m shift kit, 3.73 gears, and 3 inch cat back with a flowmaster? I am looking for 12's. I have at least 400 hp on the engine, so what do you guys think?
1989 Camaro RS
355 engine (in machine shop) approx. 400 HP
Turbo 350 w/B&M Shift kit
3.73 Richmond Gears
No Emissions or computer
Daily Driver (till Camaro is done)
1972 Pontiac LeMans 2Door
red with tan top
350 V-8
Edelbrock Perf. Intake
"Worked" Rochester Carb
Turbo 350 tranny
Dual Exhaust w/Glasspacks
1989 Camaro RS
3.73 Richmond Gears
red with tan top
350 V-8
Turbo 350 tranny
