Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
My Dyno Numbers
Old May 18, 2012 | 10:56 PM
Camaro4663's Avatar
Car: 82 camaro NA
Engine: 350 board .04 over
Transmission: turbo 350
Axle/Gears: Moser 9 inch 4.56
My Dyno Numbers
Well finally got my motor done and all hooked up its a 350 .40 over comp cam and stock unported camel hump heads, holly 750DP, and just regular flat top pistions it made 292.24 rwhp and 306.51 rwtq they said im loosing alot in the trans with how bad its slipping and said it needs a bigger intake manifold not to bad i think for old camel humps and going through a slipping trans and my 9inch rear end im anxious to see what time it will run at the track
Old May 18, 2012 | 11:18 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: My Dyno Numbers
Not bad, I threw together with parts laying around, a .040 350, vortec heads, com cams roller cam, performer intake, shorty headers and roller tips, made 311 rwhp and 348 tq, that was a 10 bolt and T56 gears. With your Trans and diff, it would have been allot lower.
Old May 18, 2012 | 11:52 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Re: My Dyno Numbers
What's the cam specs?
85T/A350's Avatar
Engine: 350 Vortec
Re: My Dyno Numbers
What was the cam specs on yours too? The combo is very similar to mine.
Old May 19, 2012 | 01:09 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: My Dyno Numbers
Extreme energy, 236/242 @.050, .520/.540 lift on 110 lsa. It was a pretty mismatched setup.
Old May 19, 2012 | 09:17 AM
Camaro4663's Avatar
Car: 82 camaro NA
Re: My Dyno Numbers
the cam is a comp cams extreme energy cam its a solid flat tappet cam. .501/.510 lift Duration @ .050" Lift: 236 intake 242 exhaust car should run real good got everything else built good TH350 trans manual valve body with a 10 inch TCI Competition torque converter 3500 Stall Chromoly K member and A arms, 90/10 front struts with Moroso Trick springs, manual steering, electric water pump, electric fans, heater core taken out, Converted to manual breaks, 3 way adj shocks in back, Sub Frame Connectors, UMI adj Torque arm, Moser 9 inch rear with 35 spline axles 4.56 gears and full spool with Strange Pro race 4 piston aluminum calipers in rear. An aluminum front bumper support and some other weight loss things curious to get it weighed
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
