need help lowering et's
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
I was dissapointed in the times I run last Saturday.....only pulled a 14.1 at 96 with a 1.9 60 ft..... my car has full exhaust built tranny with shift kit and slightly bigger stall, Holley stealth ram intake, ported 083 heads, and 275/40/17 tires and my car weighs 3560 pounds with me in it....I was really hoping for a high 13
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: need help lowering et's
Stock cam?
Were you spinning a lot?
Car: 1986 z28
Engine: 350 hsr
stockish cam..not completely sure of the specs since it was in it when i bought it......not really i just stalled it and rolled into the throttle and it dint really spin at all....my stock tach doesnt work and i dont have a shift light so i couldnt manually shift it(couldnt hear my car over the competitor) and it was my first time drag racing
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
More power, less weight. LOL, that is what makes my cars run in a straight line.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Get rid of the 17" rims and use some 15's to give the tires a bit more sidewall to work with. Put some sticky tires on the rims.
Find some way to take at least 200 pounds out of the car. The less weight you need to move, the faster you can go with the same amount of power.
Car: 1986 z28
Engine: 350 hsr
Also running kyb gr2 shocks and strut with moog "iroc" springs
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
What was the weather like? Mississippi this time of the year is not very friendly to low ET's! Come fall, you may be well into the 13's.
Car: 1986 z28
Engine: 350 hsr
DA was 2200 so very far from optimal.....we were in humid *** louisiana weather too
MrPackstin
Oct 25, 2017 08:09 PM
