Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
lca location change...will it make handling different.
Old Sep 20, 2012 | 08:50 AM
jpoeling's Avatar
I need to move the lca on our 88 bird to fit the 27x14 tires. Under hard cornering the tires are deflecting enough that they are rubbing the inner fender well and the lca. I have already started the mini Tub for the fender clearance. My ? Is if I move the spacers around so that I the lca is inward 1/2" more will this change any handling or be basically unchanged . Here is a photo of how it looks
Old Sep 20, 2012 | 10:32 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Re: lca location change...will it make handling different.
Go ahead and move it inward as far as you can. The actual mounting points have not changed and it will still hangle the same.
Frozer!!!
Jan 19, 2024 04:55 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
sreZ28
Aug 14, 2015 07:48 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
NBrehm
Aug 5, 2015 07:57 PM
