Knocking 6.0
Subscribe
Oct 11, 2012 | 10:47 PM
Took the TA for a ride, started knocking. Funny it waited till it was in another car. Will never know the results, so that makes me sad.
Reply 0
Oct 11, 2012 | 11:30 PM
Re: Knocking 6.0
PS, I blame it on Matt and his bad luck....lol
Reply 0
Oct 12, 2012 | 01:07 AM
Re: Knocking 6.0
Ouch, sorry to hear that
Reply 0
Oct 12, 2012 | 02:42 AM
Re: Knocking 6.0
Say it aint so brother..say it aint so
This is my fear when I swap my 6.0 into this new car after winter..something goes wrong from it sitting lol.Cross my fingers.
Reply 0
Oct 12, 2012 | 05:37 AM
Re: Knocking 6.0
It is all good, ony thing I regret is that I did not get to tothe track as planned. Which was in 7 days...
Going to see what the damage is and if I can rebuild at a decent price. If not, junkyard round 2 6.0. Friend is offering up his 446 ci LSx block with ls7 heads. Maybe I'll do that for now.
Reply 0
Oct 12, 2012 | 06:53 AM
Re: Knocking 6.0
lots of breakage happening in the TGO camp, lol. sounds like 2013 is going to pay dearly for taking our hotrods away in 2012!
Reply 0
Oct 12, 2012 | 08:42 AM
Re: Knocking 6.0
did you make any changes to the engine since it ran last time? is the transmission the same as well?
oil cooler changes? oil change?
Reply 0
Oct 12, 2012 | 08:52 AM
Re: Knocking 6.0
Sucks to hear. Praying i dont have motor issues in either of
My cars. Have been having problems with shifter, rear end, and gas tank lol
Reply 0
Oct 12, 2012 | 02:46 PM
Re: Knocking 6.0
You will hopefully be fine. It is the rest of you parts you need to worry about, lol.
Diggler, motor was untouched. Just swapped from the 6 speed 89 RS to the th400 86 TA.
Reply 0
Oct 12, 2012 | 06:06 PM
Re: Knocking 6.0
Man...i thought the ls motors were Gods motors??
Lol sorry to hear about the bad news!! Good luck and ill hope it has a speedy recovery.
Reply 0
Oct 12, 2012 | 06:39 PM
Re: Knocking 6.0
Thanks man, I will see what can be saved. Have a 4.8 I could throw in that has 243 heads. Wonder how it would react to a Trex cam? Lol
Reply 0
Oct 12, 2012 | 07:16 PM
Re: Knocking 6.0
My buddy has done trex twin turbo 4.8. Didnt last long but it was an animal haha. It idles at about 2-3 inches of Hg lol. It would spin 8000+ with trex. The old 230 deg cam peaked at 7400-7500 i believe so a trex 240's cam is gonna spin up
Reply 0
Oct 12, 2012 | 07:26 PM
Re: Knocking 6.0
Of course I read this thread right before going to the track, everyone is breaking lately...Paranoia at it's finest.
After my second pass, I smelled something new, and it didn't smell good. Keeping in mind this and the other threads, I decided to just drive home and not push her too hard. Not going to worry about it though, a swap is coming soon. Was a good little 305 for the 6 months I beat the hell out of it.
Reply 0
Oct 12, 2012 | 08:55 PM
Re: Knocking 6.0
haha, yeah, i'm thinking of throwing my heads/cam/intake on a 4.8 or 5.3 if the damage is more than the cost of a junkyard shortblock.
Reply 0
Oct 12, 2012 | 10:42 PM
Re: Knocking 6.0
I want to see how much that 4.8 can hold but am not exactly that much into seeing if my single springs will hold without valve float. The worst part would be destroying the 243 heads. So, I may swap them for the ported 853s and port the 243s for the next 6.0 or whatever serious engine goes in the TA next.
Reply 0
Oct 12, 2012 | 10:49 PM
Re: Knocking 6.0
wonder if you'd need to flycut the 4.8 since it has flattop pistons
Reply 0
Oct 13, 2012 | 01:18 AM
Re: Knocking 6.0
I wondered the same, the 853 are not milled. So that would help.
Reply 0
Oct 13, 2012 | 08:41 AM
Re: Knocking 6.0
Yeah theres been quite a few reports of 4.8's spinning 7500 rpm. Some stock so with rod bolts.
Id do rod bolts for sure as any cam heads setup on that few cubes will spin up
Reply 0
Oct 13, 2012 | 01:45 PM
Re: Knocking 6.0
It is all up in the air. If I did the 446, I would need a intake. Rather not buy one if it will not be used for a long time. I don't even want to pull the engine from working so hard on so many cars right now. Kind of burned out. I do at least want to pull it and break it down. See what can be done.
Reply 0
Oct 14, 2012 | 12:51 AM
Re: Knocking 6.0
Quote: haha, yeah, i'm thinking of throwing my heads/cam/intake on a 4.8 or 5.3 if the damage is more than the cost of a junkyard shortblock.
Wouldnt be the first time you built a high revving, small v8.
Reply 0
Oct 14, 2012 | 05:54 AM
Re: Knocking 6.0
Man, really really tempted to try the 4.8 with ported heads, but then I would have to yank it from the truck. Have the 4.8 for the camaro that is a older piece...why the hell did I sell the spare 2008 4.8?...
Reply 0
Oct 14, 2012 | 11:38 AM
Re: Knocking 6.0
Later years came with stronger rods and 243 heads. They make better platforms
Reply 0
Oct 14, 2012 | 03:29 PM
Re: Knocking 6.0
And you are telling this to a ls1tech moderator, why? Lol
The newer engines are more expensive because of what they are as well.
Reply 0
Oct 14, 2012 | 08:58 PM
Re: Knocking 6.0
Check converter bolts - they have done that to me few times past following motor/trans separation.. Can hope that's all anyway, the 2 times it happened to me sounded like motor knock.. But usually that goes away under load. Hope no major issues.
Reply 0
Oct 14, 2012 | 11:01 PM
Re: Knocking 6.0
446 with ls7 heads sounds good to me. Sorry for the bad luck man hang in there
Reply 0
Oct 15, 2012 | 03:55 AM
Re: Knocking 6.0
Hey, at least I did not kill a built motor. No biggie.
87 TA, the oil pressure took a dump, and the 7/16 converter bolts are more than tight, lol.
Thanks for the hope.
Reply 0
Oct 15, 2012 | 06:42 AM
Re: Knocking 6.0
Yeah its amazing it lived this long the way you beat on that thing. That thing rpms. Had to die eventually. To bad it had to die before seeing what it could do in an auto
Reply 0
Oct 15, 2012 | 08:49 AM
Re: Knocking 6.0
That engine was screaming knock knock knocking own heavens door.
Reply 0
Oct 15, 2012 | 07:06 PM
Re: Knocking 6.0
I would love to get away with a hone, bearings, turn the crank, resize rods with ARP and slap it back together. Maybe port the 317s out.
Reply 0
Oct 16, 2012 | 07:44 PM
Re: Knocking 6.0
Looks like I will have a 99 6.0 short block Friday. Woo hoo. Still going. Will just need some head bolts and gaskets.
Reply 0
Oct 16, 2012 | 08:52 PM
Re: Knocking 6.0
99...won't need the spacer on that one...got a long crank on the 99 models
Reply 0
Oct 17, 2012 | 10:26 AM
Re: Knocking 6.0
Yep. Just going to sit in the crank spacer. Sold the last for 20$ With flex plate... Because it would forever be behind a t56 right?
Reply 0
Mar 12, 2013 | 02:42 AM
Re: Knocking 6.0
Just took the ol girl apart, number one and two, one is so far gone in the bearing that the piston kissed the exhaust valve enough to knock the carbon off and barely scratch the piston. So, glad to know I should need to line bore my spare 6.0 block. Cam looks ok.
Reply 0
Mar 12, 2013 | 02:51 AM
Re: Knocking 6.0
sucks man.
That ole 6.0 was a work horse. Hurt alot of feelings and kicked some azz!
I remember when we went to go pick it up
Reply 0
Mar 12, 2013 | 12:32 PM
Re: Knocking 6.0
Yea, least she aint finished yet!
Reply 0
Mar 14, 2013 | 01:13 PM
Re: Knocking 6.0
What's the going rate for a 6.0 long block these days?
Reply 0
Mar 14, 2013 | 01:23 PM
Re: Knocking 6.0
Depends where you find the deal. That one was 700$ intake to oil pan. Got my money's worth. Lol.
If I had to buy another I would go for a LY6. But I'm good with the spare from the crushed 3/4 Ton.
Reply 0
Subscribe
