Tires for vette wheels?
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Anyone have a good suggestion for 18 inch rear y2k vette wheels that will perform OK on the strip but pass inspection? Its a weekend cruiser that I might try to see what I can run for curiosity sake. It needs tires now, so I was thinking something that will pass inspection but hook up the best it can.
Thanks!
Meant to post this in the tires and wheels section.. Sorry about that.
Thanks!
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: Tires for vette wheels?
Nitto Drag Radial
305 35 ZR18
305 45 ZR18
MT Et Street
305 35 R18
305 45 R18
315 30 R18
345 35 R18
however I CANNOT SAY IF THESE WILL FIT WITHOUT SOME SURGERY TO THE REAR WHEEL WELLS
305mm = 12" wide 35 % SIDEWALL HEIGHT = 4.2"
SO THIS TIRE IN INCHES IS; 18 + 4.2 +4.2 = 26.4 TALL (same as oem 3rd gen) but IT'S 12" WIDE. the OEM tire was 245MM or 9.65"
You may have to remove the bump stops, cut off the bump stop mounting bolts, dissect the lower fronts of the wheel house. etc.. it depends on the wheel width and backspacing.
I had to do this just to mount 28x10.5-15 slicks on 15X8 wheels with 5 1/2 backspacing.
305 35 ZR18
305 45 ZR18
MT Et Street
305 35 R18
305 45 R18
315 30 R18
345 35 R18
Car: 1988 Formula
ummmmm yes. the OEM Size...
Either brand I mentioned makes sizes that will work without modifying the wheel wells.
Assuming you have the 16" wheels:
MT ET street radial has a 255 50 R16 (10 mm wider than stock)
Nitto NT555R drag radial has exact match to OEM size 245 50 R16
I used the Nitto for 14 years... very happy with them on the street.
but any drag radial has a shorter tread life... (softer compound) so if you do a lot of driving expect to replace them every 15-20K miles or more depending on how you drive.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Check to see if there is a 275-40-18 or 275-35-18 drag radial on the market -those will fit on 9.5" wide wheels with the right BS pretty easily.
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Found that they do make all three, Nitto, BFG and MT in smaller sizes. I'm going to go this route since it doesn't involve hacking up my car. Thanks for the help guys!
