Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
nothing better to do last night at 4 in the morning
Old Aug 14, 2002 | 04:58 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
went out last night and did soem g-tech runs
pulled 16.1x for 4 out of 5 runs
the 5th I tried I rev it up to 6000rpms then slip the clutch
the ret it was 3k rpms slipping the clutch
here are two of the runs
http://rx7speed.homestead.com/files/16.mp3
http://rx7speed.homestead.com/files/oops.mp3
can you guys help me out to get my times down
last time I was at the track it was a 16.4 at 86.x with a 60' of 2.4
Old Aug 14, 2002 | 07:56 PM
muchwhitesmoke's Avatar
Car: for now i have a 79 firebird that had a toasted 301 (imagine that!)
Engine: well i *had* a 301, but there is a pontiac 350 on the stand to get me on the road again and a 428 after that :D
Transmission: th350
sure
i'll help get your times down, i kno wnothing about rotaries, but i 'll help if i can
Old Aug 15, 2002 | 02:51 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
yeah well you should know quite a bit soon
I´m finding all my old post and going to try to do a write up on it
and you can read this
https://www.thirdgen.org/techbb2/sho...threadid=29292
and I wonder why they call me a post *****
Old Aug 21, 2002 | 01:34 PM
psycomaross's Avatar
Nody calls you a post *****. You just try to be one
Old Aug 21, 2002 | 06:16 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
guess I´m not trying hard enough
hey do you ever check your PM´s
Old Aug 22, 2002 | 01:59 PM
Do you ever clean yours out? I tried to PM you and your mailbox was full
Old Aug 22, 2002 | 03:02 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
hehe
oops
I have now
oh and if someone could please put a msg on CC about the whole friday thing
I can't get on there
Old Aug 22, 2002 | 06:12 PM
Gta-Paladin's Avatar
Hows your suspension.. obviously you dont have the torque that we do but what are your launches like? lots of slippage? 84 mph isnt very high...
Old Aug 26, 2002 | 03:24 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
my susp sucks at the moment
the rear end just squats really bad.
and it seems I either get a lot of spin or wheel hop or I just bog the motor down.
the only thing is though I don't want to get a setup just for drag racing as auto-x is what I would rather do
stock spring rates are something like 118 front rear
while I am wanting to go to a 350/225 f/r with koni yellows for shocks and poly bushing
just hope that will help my drag a little as well
Old Aug 27, 2002 | 12:21 AM
rx, as you can see i have an eibach pro kit and yellow koni sports all the way around.
I was running 2.6 60's before i installed this setup, so i figured it couldnt get much worse. Well guess what? It improved 100 fold. In drag racing you need a sloppy front end and a stiff rear end. My rear before was so loose it would just COOK the tires (2.6 60's are very indicative of that.) Now dont get me wrong the front struts ARENT 90/10's there nowhere even close, just that a properly FUNCTIONING rear and good struts up front in combination with the new springs lets me PLANT and go. It's a beatifull thing really. I've got a buddy with a BOXTER S. Before the swap he used to school me, after the swap i pulled so hard out of the hole he couldnt recover, even when we reached HIS rpm band it was just oo much.
This goes to prove you CAN have your pie and eat it too... And hey, when you're not running the times you want with an auto X setup just make more power and add bigger slicks
-Thanos
Old Aug 27, 2002 | 03:10 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
I figure the same with my car
nothing will make it get any worse
just everything on my car is so old and sloppy that I can´t plant on the ground. even with the auto-x springs I could prolly do better. and if nothing else just new struts and bushings would prolly do a world of good
oh yeah just another thing that sux
4 wheel steering.
under accel the rear wheels get toe in and I think a little bit of camber though not sure on that last part.... and IRS sux big *****
Old Aug 27, 2002 | 06:47 PM
rjmcgee's Avatar
Hey rx7speed, that other post was locked so I thought I would say this here. I was just after psycomaross and shouldn't have said anything towards you, so I apologize. I shouldn't have said anything about your drag racing event. Hell, I used to have a rx7 and they are fun, but I will never go back. Got to love that torque
Old Aug 27, 2002 | 09:13 PM
ladies, cant we all just get along.
RX tell me how it goes
Old Aug 28, 2002 | 03:00 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
uh my tires where low so I inflated them... I think I over inflated them a tad bit due to a tire pressure thing that was sticking.... no I have no grip....
still working on things though
rjmcgee it's cool
just was kinda curious where that one came from
SRKLEGIN
Oct 29, 2015 06:38 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Derrick86
Oct 1, 2015 05:12 AM
aaron7
Sep 30, 2015 09:15 AM
gord327
Sep 29, 2015 10:18 PM
