Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
CTW wheels
Old Feb 13, 2013 | 12:44 PM
cagedruss's Avatar
Car: 84 Camaro Z28
Engine: 5.3
Transmission: Tremic 6 Speed
Axle/Gears: 3:43 posi
CTW wheels
I received my set of Black CTW Motorsports wheels today for my race car. If anybody in the Portland area would like to come by and take a look you are more than welcome in case you were thinking of buying a set. It is nice to look before you buy.
Shop is at 4040 SW Macadam Ave, Portland. Happy to discuss with fellow third gen owners.
Old Mar 1, 2013 | 11:37 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: CTW wheels
Didn't realize you were in the Portland area. I'll have to swing by sometime, I live in the Beaverton area. I assume you track the car at PIR? I work for the drag strip.
Old Mar 1, 2013 | 12:49 PM
cagedruss's Avatar
Car: 84 Camaro Z28
Engine: 5.3
Re: CTW wheels
Yes, please do. We race the camaro at PIR, The Ridge, ORP and Spokane. We are generally here also on weekends working on the Camaro getting here ready for paint and prep for next race in April.
Old Dec 30, 2013 | 04:49 PM
cagedruss's Avatar
Car: 84 Camaro Z28
Engine: 5.3
Re: CTW wheels
New paint for 2013 series, maybe changing it up for 2014.
Old Aug 6, 2014 | 12:46 AM
DirtySpleen's Avatar
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
Re: CTW wheels
What hood is that?
Old Aug 6, 2014 | 01:29 AM
cagedruss's Avatar
Car: 84 Camaro Z28
Engine: 5.3
Re: CTW wheels
A custom creation of scrap aluminum I had laying around the shop. I had a the typical Z cowl induction hood and it was to tall for some to see while riving so I made one that was shorter and a bit wider to cover up some flaws. I needed something to give the middle some rigidity, hood is just the outer skin,
.Its made from 3 out pieces and 2 inner pieces for structure.
Its more function than form.
Old May 19, 2017 | 08:55 PM
cagedruss's Avatar
Car: 84 Camaro Z28
Engine: 5.3
Re: CTW wheels
I haven't posted in a long time. My bad. I wanted to post an update on my CTW wheels. I was at a Endurance 2 weeks ago at a track called The Ridge Motorsports Park in Shelton Washington. I had a little side by side contact with a BMW with long wheel studs.
The long wheel studs caught the lip of my right rear wheel and I was unaware of the actual damage until I came in for a driver change and fuel.
I am grateful the CTW Motorsports wheel is robust and was able to handle the abuse without failing and also the sidewall of the BFG's held up. The track has some very fast left hand turns and was fortunate the wheel didn't fracture even more or lose the tire altogether. I raced another 50 mins or so on the wheel so anything could have happened. I did swap it out to a spare after seeing the damage.
I did contact Paul and thank him and even sent the wheel back to him so he could inspect it.
Thought you guys might want to see it also.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
