Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
Cat was the problem...
Old Oct 24, 2001 | 07:21 PM
[-sLaYeR-]'s Avatar
As some of you might remember I was having heat problems with the car. When it got too hot it would stutter while starting from a complete stop. I changed plugs, wires, cap and rotor, etc... and nothing seemed to help. If anything it made it worse. I had to recently get my Exhaust done; and when I did, I found out the cat was toast. When I changed that, as well, the car no longer shoots out smoke at startup.(I though that was the valve seals) If I leave the car idle it no longer gets near as hot as it used to. Figured I would let everyone know this, just incase you have a similar problem. Check the cat, it might be the problem. BTW, aircare sucks but I passed
'91 RS 305 5.0L V8
Bowtie Grill & Lamps, K&N Air Filter, Centerforce Clutch, and of course stereo
http://24.77.81.202/Jay/index.html
Old Oct 25, 2001 | 03:17 AM
Roshambo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by [-sLaYeR-]:
</font>
Cool, glad you got it figured out man!
-Roshambo
-Joe
1988 Pontiac Trans Am WS6 - 305 TPI, 700R4, 3.23 Posi, Digital Dash, Leather Seats, Maui Blue with Silver GFX, T-tops, Tinted Glass, Gutted MAF, TB Coolant Bypass, K&N Cone Filter, No Cat, 3" exhaust from Y-pipe back, MSD Super Coil, Accel 8mm wires, L98 Aluminum Heads, Ported and Polished Plenum, Siamesed Intake, Aluminum Driveshaft, Edelbrock 3 point Strut Tower Brace
Old Oct 25, 2001 | 06:53 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Hey mine is doing the same, just changed plugs and wires, and didn't help, i am pretty sure my cat has seen far better days, maybe that will help cause my car is doing exactly what you described
Old Oct 25, 2001 | 10:23 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Good news. But hate to tell you...your valve stem seals still leak. The new cat is just burning the fumes. If it use to smoke alot the cat probably wont last long. The xtra fuel(oil) in the smoke will eventually either plug or overheat the new cat. I finally gave up on mine and cleaned it out. No emission here anyway.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
