Pacific Region Regional board for Pacific Third Gen owners.
While I have the throtle body out....
Old Aug 15, 2005 | 11:53 AM
jcpegg's Avatar
*DELETE* posted in wrong forum
What should I clean, inspect, replace, etc... I've only had this vehicle for a few months, so I have to assume that the throttle body has not ever been serviced. A little advice on how to remove/clean specific parts would help a lot since I'm new to fuel injection.
Old Aug 15, 2005 | 06:33 PM
CrazyHawaiian's Avatar
Car: too many ...
I would recommend removing the TPS and IAC and throughly cleaning both. I would also clean out the IAC air passage and the rest of the inside of the TB in general. Carbon buildup can cause the TPS and IAC sensors to go whack. Remember to set both TPS and IAC correctly when re-installing. IAC pintle should be no more than 28mm from tip to flange and TPS should be set to .54V at full closed (need to use a DVM to make sure).
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Kenwood
Sep 4, 2015 05:50 PM
