Pacific Region Regional board for Pacific Third Gen owners.
Fuel Pump going?
Old Mar 20, 2006 | 02:07 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Fuel Pump going?
Hey, Ed, what were the symptoms of the fuel pump going kaput? I think my TTA's pump is going out, but I could be wrong (I hope it's just the MAF). the car stumbled and almoste died when I tried nailing it, felt like it wa running out of gas (it isn't), and it kept doing it so much that I parked the car and drove teh GTA to work. I'll probably be driving the GTA for a time until I figure out and fix the TTA. Drives nice and the leather seats are comfortable...
Old Mar 20, 2006 | 10:46 PM
3rdGenBlackBird's Avatar
Lower fuel pressure, higher current draw, more noise, or intermittently not working.
Replace your filter if it's not new and check your pressures. I don't know what to look for as far as amp readings, but if you can find specs for the normal range you can measure that too. You can also diagnose it on a scope if you have one lying around.
Or... swap it with the GTA's pump and see if that fixes it or not. (Yeah right....)
Scott
Old Mar 21, 2006 | 01:17 AM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Unpluggin the MAF killed the car. I got some miftly troubleshooting guide from a guy at turbobuick.com, I'm suppose to see 40-something PSI at the schrader valve when I first turn the car to run - the pump kicks in for a second or two, to build up pressure. As soon as I get a fuel pressure gauge, I can verify if I have the appropriate pressure readings, and that it doenst' leak down once the pump turns off. Neat stuff, this Internet thing...
Here's hoping it isn't the pump, either...
Old Mar 27, 2006 | 03:22 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Okay, update! Turns out my air box lid was loose. I was getting water from all the rain we've been having into the air box, hence, it got injested, where it clogged the MAF and filter and ended up into the intercooler. (Hooray for the intercooler, lowest part of the air intake system!) So, I unplugged the MAF, ditched the filter and left it with just the MAF pipe on, and it ran a LOT better. I've yet to drain the intercooler, though.
Old Mar 28, 2006 | 04:50 PM
So, you'll be prepping for the track this weekend then? Right on Ian!
Old Mar 29, 2006 | 10:19 AM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Yeah... As soon as I can get my stupid intercooler off...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
