Pacific Region Regional board for Pacific Third Gen owners.
TPI to carb
Old Oct 21, 2006 | 05:29 PM
limptrzkit's Avatar
Car: 92 Z/28
Engine: 355ci. /only connecting rods stock
Transmission: TCI Streetfighter auto
Axle/Gears: stock 3.23 :(
TPI to carb
so i have no clue what to do w/ the return fuel line from the original TPI setup. it just pours out gas until i undo the gas cap and release the pressure. right now its just sitting open and obviously theres nowhere for it to go for the carb set-up....well, that i know of...any suggestions?
Old Oct 21, 2006 | 06:00 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I used a Mallory 4309 return style regulate when I switched from TPI to carb. It cuts down the pressure for the carb and returns excess fuel to the tank.
You can find them on either Summit or Jegs sites.
Old Oct 22, 2006 | 04:36 AM
limptrzkit's Avatar
Car: 92 Z/28
I forget what pressure regulator i have on there, but im pretty sure its a mallory. anyways, i have one inlet and 2 outlets on my regulator. obviously one of them goes to the carb...is the other one for the return line?
Old Oct 22, 2006 | 06:16 AM
Blackroc86's Avatar
Car: 1986 Iroc
Yes you have to use a return line to return the excess fuel to the tank. If you have the Mallory regulator the instructions should show you how to route the lines.
Old Oct 22, 2006 | 04:07 PM
limptrzkit's Avatar
Car: 92 Z/28
sweet, thanks a bunch. this is my first experience w/ carbs so i dont know that much about them. eh, i'm learnin tho. anyways, tks again
Old Nov 5, 2006 | 11:35 PM
Brettlinetta's Avatar
Car: 85' Berlinetta
Engine: Twin Turbo 350 coming soon
Transmission: TH350
Axle/Gears: 10 bolt 3.42 posi
You don't still have your TPI setup do yeh?
-Brett
Old Nov 6, 2006 | 12:13 AM
limptrzkit's Avatar
Car: 92 Z/28
no, sorry, i already gave it to somebody
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
