Cat Hanger
Car: 88 TA
Engine: 5.7 TPI
Cat Hanger
Im looking for a Catalytic Converter hanger from a firebird that was used for the factory 3 inch cats. Came with L98's engine code F I believe I currently have the 2 1/2 to 2 1/4 cat and the bracket doesnt match. Throw me a price.
Thanks.
Thanks.
Car: 87' Pont GTA
Engine: 5.7L
If you can E-mail me a picture of your old one I probably have one. They used many different styles. They run $10.00 plus shipping and handling.
Thank you,
Thomas
(800) 460-6789
www.houseofcamaro.com
Thank you,
Thomas
(800) 460-6789
Car: 87' Pont GTA
Engine: 5.7L
Yes, I do have the # 14089475 that you are requesting. Here is a picture.
Thank you,
Thomas
(800) 460-6789
Thank you,
Thomas
(800) 460-6789
Car: 87' Pont GTA
Engine: 5.7L
It is about 2 3/4" from center to center. I hope that helps!
Thank you,
Thomas
(800) 460-6789
Thank you,
Thomas
(800) 460-6789
Car: 88 TA
Engine: 5.7 TPI
Few more things.....Seeing as u have almost any part I would need....Do you have these as well?
Accelerator Plenum Bracket
14084305
Throttle cable retainer
15567924
Accel/Cruise clip (Piece that goes 3 inches behind the plenum bracket)
8917256
14084305
15567924
8917256
Car: 87' Pont GTA
Engine: 5.7L
Sorry, but I am at a loss on Part Numbers unless they are stamped on the part itself. I think these are the items that you are requesting? If so the Cable Bracket which holds the Throttle, Cruise Control and Transmission TV Cables runs $10.00. The Throttle and Cruise Cable Clips run $1.00 each. The Throttle and Cruise Control Cable Holder runs $3.00 plus shipping and handling. Here is a picture of these items.
Thank you,
Thomas
(800) 460-6789
Thank you,
Thomas
(800) 460-6789
Car: 88 TA
Engine: 5.7 TPI
1 final thing i need and that should complete my first order. I need the long tube that connects the fuel rails in the back. Oh I also could use the throttle cable for an 88 TPI that connects to the petal. Thanks
Car: 87' Pont GTA
Engine: 5.7L
BY the Long Tube are you refering to the Cold Start Valve (9th Injector)? If so I do not have that by itself. The Throttle Cable runs $10.00 plus shipping and handling.
Thank you,
Thomas
(800) 460-6789
Thank you,
Thomas
(800) 460-6789
Car: 87' Pont GTA
Engine: 5.7L
Sorry, but at this time I do not have that item in stock.
Thank you,
Thomas
(800) 460-6789
Thank you,
Thomas
(800) 460-6789
Car: 87' Pont GTA
Engine: 5.7L
LT1Formula
Oct 8, 2015 08:34 PM
