do they make a cold air intake for a 87 GTA TPI setup?? if so, where and how much....anyone have one?
If you use a cold air for a 4th gen LT1 setup and an LT1 style elbow, relocate or remove the charcoal can, cut a hole in the spot where the charcoal can sat, remove or relocate the sputnik looking vacuum can and do a little baffling in front of the driver side tire to prevent water from spraying on the filter from the tire, and you are done.
Sounds confusing and like alot of work, but it isnt bad at all. I am assuming that the charcoal can on your car is on te driver side where the battery is on the other side. I used a K&N FIPK kit.
There is probably an easier way, but this is truly a cold air intake as the element is completely outside of the engine bay. It works well.
check out slponline.com
http://www.slponline.com/view_product.asp?P=21000
its a little expensive but i bought one and i love it. i put the cold air intake and march performance pulley set on and they took off half a second in the quarter.
what happens with your MAF sensor when you put this system on?
