how much psi on a modded 406?
Old Apr 25, 2002 | 05:41 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
well i planeed on running a 150 shot on my 406, but decided to go with an ATI procharger. the engine is forged bottom end, AFR 195 heads, ect.. 10.4:1 comp. but my main concern is how much psi i can get out of the s/c *with intercooler* . if im only going to make 150 hp on the s/c then ill just go back and get the NX kit. but if i can run like 8-9 psi on the engine and make alot more hp then ill be happy. BTW.. im guessing il have to get bigger injectors. 30# SVO's good enough?
Old Apr 25, 2002 | 07:23 AM
Guido's Avatar
Car: 2000 Trans Am
http://web.camaross.com/bb/Forum2/HTML/007583.html
Old Apr 27, 2002 | 07:46 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
That sounds like what Darcom sorta has done. see it here: http://darcom.home.texas.net/darcom/Z28_PAGEx.html
Old Apr 29, 2002 | 01:21 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
And Darcom runs what psi?? What times does this get him?? None I know of. I then believe his car should be negated for discussion.
Old Apr 29, 2002 | 01:31 PM
rhuarc30's Avatar
It depends on what mods you've got. As a guess, around 200-250, with similar low end torque gains.
Old May 3, 2002 | 10:53 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I'm going for 15 psi on my 412, but it is very modded now.
dusterbd
Sep 29, 2015 08:40 AM
