Ignition recurve kit and nitrous????
Old Aug 9, 2002 | 08:49 AM
mefreema's Avatar
Is it safe to use an ignition recurve kit while using nitrous. I know it brings in the timing faster which is better for normal asperation but could that get dangerous with the use of nitrous. I am running an edelbrock 50-75-100 plate kit so it's not a huge shot or anything.
Old Aug 9, 2002 | 12:34 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
if base timing is reduced and fuel quality is ok then I think it will all be good.
Old Aug 9, 2002 | 01:02 PM
mefreema's Avatar
I run premium (92 octane) and run 6 degrees (stock) base timing. I have been wanting to bump that up though. Currently I am running the 50 shot for the streeet but come track time I'll go to the 75 and if things seem good eventually the 100. I guess I would pull out a couple degrees when I go for the bigger shot but was not sure about the recurve kit. Mechanically my timing would be all in around 3k 3.5k? As opposed to somewhere around my redline.
Old Aug 9, 2002 | 01:42 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I think you will be fine that way up to above 150 hp levels maybe more
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Jlanz55
Sep 6, 2015 02:35 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
