Experienced N2O users inside......
Old Aug 23, 2002 | 06:04 AM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
I`ve been told not to rely on my wide-band when on the spray,but to read plugs as a tuning guide. I`ll cut the engine off at different rpm`s and check them that way,but I need to know what I`m looking at.How do you tell if your rich/lean,too much/too little timing etc. etc.? Please be as specific as you can!
Thanks,
Glen
Old Aug 23, 2002 | 11:52 PM
BlownBird's Avatar
Little help here??? Anyone???
Old Aug 24, 2002 | 12:12 AM
89ProchargedROC's Avatar
Checking plugs can give you *somewhat* of an idea of how the motor is running, but the only way to REALLY tell is after you are done with the 1/4 pass you shut the motor off and then check the plugs because on your way back to the pits they can change
Are you running a dry kit or a wet kit?
Who told you to not rely on the wideband on the spray?
--As far as plug readings goes.....you want the threads on the plugs to look somewhat moist, not super wet which indicates running rich.
--As far as the porcelin....you want it to have a slight tint of brown or even possibly red if running race gas or octance booster
--The tip of the plug should have some color to it but not silverish at all
LASTLY.....if your threads on your sparkplugs look as dry as a 80 year old woman and seem to have grey *sparkles* on them.....that is pieces of your pistons flaking off from detonation
How's that for a start?
Old Aug 24, 2002 | 01:11 PM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
Roc,
I`ll file that in the ol` memory bank. That`s exactly how I was going to get a reading,cut the engine at WOT.How far up the porcelain should the "ring" be,at the base?
A few people on the TurboBuick board including Craig Smith told me about the wide-band. FWIW I`m seeing an average A/F of 12:1,and friends have reported a rich condition from out the tailpipe as I make a pass.
Just installed a 9" converter(drove thru the 10")and new, wider ET Streets.
Heading to the track this Wed. night to test,I`ll look at those plugs then. Appreciate the feedback:hail:
Oh yeah,it`s a wet kit.
Old Aug 26, 2002 | 10:11 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
I've been using my wideband O2 to tune my nitrous system & it seems to be working well - haven't read the plugs, though, so I'll do that nest time I run. I set the NOS afr to approx 11.8:1 & the N/A afr to approx 12.8:1 with the wide band. The only time the wide band does not work - it reads minimum scale @ WOT - is when I run 100 octane unleaded - other than that, it seems to work fine with 91 octane unleaded.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
camaro1185
Oct 26, 2015 06:51 AM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
david068513
Sep 18, 2015 10:36 AM
