ATTN: European members
Old Aug 29, 2002 | 10:04 AM
Guido's Avatar
Car: 2000 Trans Am
Do any of you guys know anything about this car??
Here is the webpage it came from. I wonder if there are additional photos of this car somewhere.
www.nitroz.se/persaker/ racing.html
Old Aug 29, 2002 | 03:57 PM
Bobalos's Avatar
I have a little German in me does that make my member European?
Anywho, that looks to me like Mechanical injection. I see a lot of tubes & what looks like valves connected to the TB's. but that is only an educated guess.
BW
Old Aug 29, 2002 | 05:33 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
That is a Swedish company. I don't know anything about that car exept what's on that page.
http://www.nitroz.se/persaker/racing.html
509 cui methanol
1550 hp @ 5252 RPM
1550 ft/lbs @ 12 PSI boost
0 - 125 mph 2.6 seconds
Old Aug 29, 2002 | 08:12 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I think everyone is forgetting something here. They have the fu*cing batmobile!
Attached Thumbnails ATTN: European members-batman-b.jpg
Old Aug 29, 2002 | 08:16 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Curt,
I'll try e-mailing pics of the car and the url to some car mags in the UK and see what they can tell me. Sometimes they go a little investigating for you and come up with the goods.
Robert
Old Aug 30, 2002 | 01:34 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
The guy who has built the batmobile is going to build total copy of the Kitt car..........Batmobile is almost ready.......
I'll see if I can find more info about the TT TA.....
Old Sep 1, 2002 | 08:58 PM
Gta-Paladin's Avatar
PONTIAC TRANS AM 1989, TWIN TURBO PONTIAC 509”
CAR BUILD BY: JERRY HAAS RACE CARS U.S.A.
MOTOR: PONTIAC V8 509" 8,340 L. Build year 2000 by DTE RACING SWEDEN. Rebuild 2002
APROX. 1550 HK @ 5252 RPM VRID = 2101 nm. 214 kp. 1550 ft/lbs @ 12 PSI
TURBONETICS Y2K x 2 HILBORN INJECTION WASTEGATE + DUMP VALVE = MADE IN SWEDEN
4,500" BORE 4,000" SLAG BLOCK MERLIN LITE ALUMINUM 9,8"
C&A C-ROD 6,385" ALUM. CP PISTONS 10,2:1 TOTAL SEAL PISTON RINGS TS1Q
HEADS PONTIAC P4 MANLEY TITANIUM VENTILER IN 2,40" 11/32" EX 1,90" 11/32"
JESEL ROCKER ARMS, COMP CAMS, MSD 10, JESEL DIST.
AUTOVERDI MADE IN SWEDEN TORRSUMPS - OLJEPUMP / VACUUM
ÅHMANS MOTOR SLIP MOTOR MASKINARBETEN. BORLÄNGE
TRANS: HAYS 2-SKIVIG KOPPLING 10" B&J 5-PET MANUELL
BAKAXEL FORD - M.W. 9,5" 4,10:1 SPOLE 40-SPLINES
VIKT: 1160 KG 2560 LBS ........................... FUEL: METANOL
OLJOA: BP VISCO 7000 SPORT 5W-50 ....GAUGES: AUTOMETER
HOSES: X.R.P. ................................................ DATOR: COMPUTECH
TEMPMÄT: SENSOR-NITE ......................... PRESTANDA: 0 - 200 km/h 2,6 sekunder
FÄLGAR: WELD RACING TIRES: HOOSIER 18600
INTERCOM: PELTOR SAFETY: GA ............ PAINT: RAY HILL
# 117 Jöran Persåker. Team: Carina + Per.
1550 HP and 1550 Ft lbs 12 psi @ 5252 rpm
What more do you need to know
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
