? about carb and N2O
Old Sep 3, 2002 | 07:07 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I have a NX TPI/LT1/LS1 kit. I have zero room for a plate kit with my intake and hood. My question is can I use this kit that I have because it is a fogger kit? can I just screw it into my air cleaner and let it spray right down the carb? Or do I have to buy a carb fogger kit? thanks
Shawn
Old Sep 4, 2002 | 02:43 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes you can use it but you will definitely need 7 more nozzles and probably bigger selenoids
Old Sep 4, 2002 | 09:15 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Maybe I wasn't using the correct terminology. I thought what you described was called direct port. I have a kit with a fog nozzle on it and I just want to be able to spray it right into my air cleaner would that work? Or does it need the Fuel pressure that the FI puts out?
Old Sep 6, 2002 | 09:14 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the required fuel pressure is fixable through jetting but trying to spray like that you have no control over how it affects the carbs operation or where the stuff is even going to go (distribution).
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
