Would 2" I.D. pipe be too small for a log style exhaust?
I've been giving some thought to using square tubing for the headers. It's strong and would be easier to cut holes for the pipes to weld to and may be able to mount the turbo on it somehow. Hmmmmmm........
Brad...
Brad...
Re: Would 2" I.D. pipe be too small for a log style exhaust?
Originally posted by bhaas
I have lots of that laying around. What would be the best size?
My collectors neck down to 2.5" right now and I'm thinking of using short pieces of 2.5 or 2.25" to connect to the turbo flange.
T3 turbine inlets have almost exhactly the same area as a 2.25" tube (although if you measure around the square opening you'll find that it's almost exactly the same as the circumference of 2.5", so if you use 2.25 you'll either have to blend the opening some with a grinder or stretch it a little) so unless you've got a lot of bends, you're not gaining anything by going larger but increasing volume/slowing spool...
hectre13
Sep 8, 2015 03:38 PM
transaero
Aug 31, 2015 01:14 AM
