nitrous on cc carb. can I ????
Old Nov 29, 2002 | 11:01 AM
dsavio's Avatar
Can I do this? and what would i need. do i have to up grade the whole fuel system? I just have a standard mechanical fuel pump now.
Dave
Old Nov 29, 2002 | 11:46 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
The computer only adjusts the carb's mixture at part-throttle cruise and idle, so at WOT when you're using the nitrous there's no problem.
Always a good idea to upgrade the fuel pump and lines with Nitrous, well worth it.
Old Nov 29, 2002 | 12:06 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
no prob
Old Nov 29, 2002 | 06:58 PM
dsavio's Avatar
So, there is no problem what kit would you guys recommend? and can i just upgrade to a better mechanical fuel pump or do i need to install a electric fuel pump? Is there a page some where to get a list of things i need to do to install this system. or has any one here done it. that is installing nitrous on a cc carbed car.
Dave
Old Nov 29, 2002 | 08:49 PM
Damon's Avatar
As long as the fuel system can hold 6 PSI when the nitrous is activated, you're OK. I HIGHLY recommend you buy a cheap remote fuel pressure gague kit available at most speed shops (and mail-order) and tap it into your fuel system just in front of the carb. Duck tape the gague to the windshield (temporarily!) and make a nitrous-on run. If you're outrunning the fuel system it will be obvious- fuel pressure will taper off in the high RPMs. If that's the case then you should upgrade the fuel system as appropriate.
I have found that a simple low pressure fuel pump like the Carter 5 PSI electric street pump installed back near the gas tank IN ADDITION TO THE BLOCK MOUNTED MECHANICAL PUMP can make a WORLD of difference in keeping constant fuel pressure under high demand (nitrous on) on a carbureted setup.
Old Nov 30, 2002 | 12:25 AM
dsavio's Avatar
damon
i have seen the edelbrock quadrajet kit for about $350.00. do you know if that is a good deal and a quality kit? thanks for the fuel system input.
Dave
RedLeader289
May 28, 2019 01:47 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
RedLeader289
Sep 23, 2015 06:50 AM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
