Compression and nitrous
Old Dec 22, 2002 | 11:09 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I know all about the retarding for nitrous but my question is would it be safe to run about 10.5-11:1 compression on about a 150 shot of nitrous. I plan on gettin a 383 but want to build it for possilble nitrous. It has 4340 H-beam rods, and a 4340 no twist forged crank. I am probably gonna have to get forged pistons too I would guess. Thanks for any info.
Old Dec 22, 2002 | 12:04 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
You can get away with a 10.5:1 with a 150 shot on an aluminum headed motor on pump gas. If your running iron heads you my want to be a little more conservative. The amount of overlap your cam has will also effect the compression. If your running a cam with a lot of overlap,you can get by with a little more compression without detonation. Yes, go with forged pistons if you plan to spray 150 shot.
Old Dec 25, 2002 | 04:42 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
For a 150 shot, you could get away with decent forged pistons, stock rods and a scat or other aftermarket steel crank for a good combo. You don't have to have 4340 everything to spray. The only reason I went the 4340 route is because I plan on a 2 stage 400 shot. There are guys around here that are spraying 250 shots on stock cranks, with better rods and pistons with 2-bolt blocks. It all depends on the total car setup. They are running 116 gas though with a lot of timing pulled out, total timing is around 28 degrees or less.
Compression doesn't matter. With higher compression, you just have to run richer on the fuel, higher octane, pull more timing, or all of the above. You won't know what the motor wants until you read the plugs or get to a dyno.
FormulasOnly
Jul 23, 2018 08:47 AM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
