Blower Bracket Shims...
Old Jan 25, 2003 | 01:49 PM
Blown WS6's Avatar
Car: 91 Formula, 92 Vert
Engine: 350 TPI, 350 LT1
Transmission: Both Auto
Has anyone had to shim thier blower bracket or the blower on the bracket? I have had to do both with my kit in order to get my belt alignment close to perfect. But its not. I still throw my blower belt at 6,000 rpm sometimes. I finally figured out which direction I need to move the blower but I need to find "machined washers" and I need a bunch of differant sizes. And I need then pretty thin ranging to thick ones in order to get my belt aligned right.
Anyone know where I can get a shim kit like this or where I can get machined washers? I tried every hardware store known to man. Any suggesstions?
Old Jan 26, 2003 | 01:25 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I just grab a bagfull of the regular wshers and use a micrometer to make sets with a sharpie pen
Old Jan 26, 2003 | 01:35 PM
Blown WS6's Avatar
Thats fine for regular to thick washers, but i need some THIN washers in order to shim my bracket perfectly. I'm not going to be afraid to rev my engine anymore in fear of toasting a $25 belt.
Old Jan 26, 2003 | 01:38 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
go to a tranny shop every good tranny builder saves all the little shims that come in the kits that didnt fit what they were working on, some are like small washers, especially if you find a tranny shop that rebuilds planetary gear sets.
Old Jan 26, 2003 | 02:42 PM
Dan W's Avatar
In a pinch an aluminum can can be cut up for thin shims.
I've seen shims out there in a stack with adhesive between each shim... you just peel off how ever thick you need them. Don't know where to find them though.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
