Pistons???
Old Jan 29, 2003 | 11:37 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
Pistons???
I'AM GOING OUT TO BUY A SET OF PISTONS, AND WANTED WHAT KIND I SHOULD BUY. I WANT TO RUN NOS SOME DAY AND DON'T WANT TO SPEND MORE THAN $3OO CDN . IF ANYBODY COULD POINT ME IN THE RIGHT DIRECTION THAN THAT WOULD BE A LOT OF HELP. THIS IS MY ENGING SETUP
350 ci bored 030 over
882 heads hevaly ported and polished
1.94 int 1.50 ext
Edelbrock perfomer RPM intake
Holley 670 Streat Avenger carb
Stock crank and rods
leaning toward a 480 lift cam from Comp Cams
and how much hp do you think I will make???
Thank you
Old Jan 30, 2003 | 05:27 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You might be able to find some TRW forged pistons for that price.
Old Jan 30, 2003 | 05:47 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
$300 cdn is like what $USD, if you have 882 you have massive chambers. trw makes a baby forged dome (.350") that is only a few tenths of an in and doesnt interfere with valve clearance anymore than a flattop would. It makes 882 76cc headed engines into more of a performing setup with around 10.5:1 compression. the cool thing about them is that if you get nicer heads the compression really goes up :-)
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
