Timing retard question
Old Apr 12, 2003 | 03:55 PM
Kiwi-85IROC's Avatar
On a TPI 305 with a NOS 100-150 wet kit added, running only a 100 shot, is it necessary to retard the timing? Its suggested that 2 deg for every 50hp is whats meant to be used.
Question is: Doesn't the TPI motor have a "knock" sensor in it already?
And: If retatding the timing is a must, won't that just completely kill any power the 305 has for normal driving?
Old Apr 12, 2003 | 04:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
By the time the knock sensor has detected detonation, it's probably already too late.
Old Apr 13, 2003 | 12:34 AM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Just get yourself an ignition box and retard that only comes on when the nitrous is active. MSD of course comes to mind but there are several. Then you can have your full timing for regular driving and still be safe for the nitrous.
Old Apr 13, 2003 | 02:42 AM
Yeah, I was lookin at MSD stuff today...think that is a good idea.
Question: After market chip which I have installed, gives me aggressive timing. Will the timing retard box that MSD makes, defeat the advance the chip is trying to acheive when I set the timing on the MSD box?
Old Apr 13, 2003 | 03:29 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
that digital 6 works pretty good
Old Apr 14, 2003 | 01:14 AM
Ok, so is it definate that the TPI 305 needs a timing retard running only a 100 shot of NOS... or is it only probably?
Problem I have is in New Zealand to get the A6 and retard box and other stuff to set it up costs around $1400.
I'll do it if I really need it, but from what I've heard a 100 shot doesn't need to be retarded, I just need to know for sure.
Anyone?
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
