fuel system?
Old Apr 26, 2003 | 12:03 AM
Kandied91z's Avatar
fuel system?
what have you done to your setup to supply fuel properly with your power adder?
Old Apr 27, 2003 | 08:37 AM
BlownBird's Avatar
Here is my setup, not for the weak at heart, but I should never need to upgrade again.
From the tank...
-12an to a Weldon filter (100 micron)
Weldon 2035 fuel pump
after pump -10 an to a Paxton fuel filter (10 micron)
-10an ran to the front to a BG Y-block
from the Y-block 2 -8an feed lines to the rails (5/8 MSD rail stock)
2 -8an lines to a Weldon regulator
out of the regulator is -8an all the way back to the tank.
With a setup like this you need a filter before and after the fuel pump. the F/I fuel pump is a pusher pump, and needs a less restrictive filter in front of it (80+ micron). And the filter after the pump is what does all the work to pick up small particles that may harm an injector.
I went with a "non-conventional" way of modifying my fuel tank.
No sump, and no bulkhead at the bottom of the tank. Instead, I installed 90* bulkheads at the top of the tank (a -12 and a -8). I made custom pickup and return tubes, flared the ends, and attached them to the bulkheads at the top of the tank. One feeds the pump, the other s the return.
Good luck with your fuel system!
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
