Upgrade Fuel system????
Old Jun 26, 2003 | 09:16 PM
TA88GTA's Avatar
Hey guys, I just want some opions/advice on wheather you guys think my fuel system will be able to keep up with my motor.
The motor is a 355 w/ 9:1 compression, eldelbrock performer rpm heads, HSR intake, twin 58mm TB, 230/236 duration@.050" and .545/.555 lift, 10lbs of boost and 50shot of nitrous. The motor should make about 500hp once tuned on the holley commander 950.
Right now the car has a 255lph intank, stock fuel line, and 24lb injecters. Im moving up to 42lb injecters, but im not sure what to do about the lines or pump. So what do you guys think, Will the stock fuel lines keep up, and will an additional inline pump be enough. Thanks in advance.
Old Jun 28, 2003 | 03:27 PM
TA88GTA's Avatar
TTT
Old Jun 28, 2003 | 07:31 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
why 42's? why commander 950? I can understand the holley stealth ram. why 500 hp? what power adder?
Old Jun 28, 2003 | 07:49 PM
TA88GTA's Avatar
Well i already have the commander 950 installed so thats what im using to tune the car. As for the power adder, the car has a vortec supercharger and nitrous, so it should be seeing about 500hp when all is said and done.
I was think of going with 42s because i was told 36s might be on the border line and im going to upgrade the charger later on. Also with the 42s i can always shorten the injecter pluse width the commander, to pull fuel out.
Old Jun 28, 2003 | 09:12 PM
zz4z28's Avatar
I am making 560rwhp with the commander 950
with stock lines, wtih 42's and an aeromotive external pump.
I never had any problems with mine!
But I will be upgrading the lines this year
for the turbos
Old Jun 29, 2003 | 05:57 AM
TA88GTA's Avatar
for the turbos
Which pump are you using? Also are you using it by itself or in conjunction with an intake?? And thanks for the reply.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
