my dyno results
Car: 1992 B4C 1LE
hang on there is alot wrong with that engine compartment the firewall strut towers everything...
is that a 4th gen engine comparment or a 3rd gen? It appears to be a compilation of both and I dont just mean the LS1...
Car: 2002 Formula Firebird
Transmission: 4l60e
Thats how a 4th gen engine bay should look. Instead they stuff the ls1 halfway underneath the dash and cowl area so you can;t hardly work on it. That car is sweet BTW. tons of custom work.
Car: 1988 Z
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What headers are you using? Are they custom or does someone make them for this swap? Did you use a tubular k-member or the stock one. I aks this because I am planning an LS1 swap as we speak but my limiting factors are header use.
Car: 1988 Z
Car: '90 RS
Engine: 377 LSX
I had forgotten that you had implemented the whole fourthgen set-up. Do you know off hand what it takes to run headers on a LS1 swap? Besides custom ones that is.
LT1Formula
Oct 8, 2015 08:34 PM
