Damon....?
Old Dec 6, 2003 | 01:33 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Damon....?
what upper pulley are you useing, and whats the size they come with
thanks
Old Dec 6, 2003 | 01:51 PM
Damon's Avatar
Stock, the 142 comes with a 3.07 upper and a 6" bottom pulley. You can get larger bottoms in 6.5 and 7 inch. For the uppers there's only one step smaller- 2.85. I run a 7" bottom with the stock 3.06 top. 5 PSI on a 383 with a moderate cam (Comp XE 268 flat tappet hydraulic ground on a wider 114* LSA). Switching to the 2.85" top would probably get me just a smidge over 6 PSI (which I plan on doing next spring).
@ 5 PSI I'm making a little over 480HP at the crank and torque is, as you can imagine, well over 500.
Old Dec 6, 2003 | 08:42 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
thanks
