crank pulley bolt pattern... diff between SBC and LT1???
Old Jan 21, 2004 | 03:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
is the bolt pattern for the crank pulley the same between a LT1 and a SBC?
im considering using a blower pulley ment for a LT1 to run my blower on my SBC.... i need to know if they will bolt together though...
Old Jan 21, 2004 | 04:30 PM
biggtime's Avatar
My procharger bottom pulley came with a big block center hole and the spacer adapted it. It was from a LT1 when I put it on my third gen. the new adapter did the same thing. the 3 bolts are on the same circle on all three of those engines. although they use different threads.
Old Jan 21, 2004 | 09:33 PM
92Z's Avatar
92Z
A non LT1 crank pulley (or harmonic balancer) is on a 3.2 dia. 3 bolt hole circle (120 degrees between the holes). The LT1 pattern has one hole offset 5 degrees. ATI slots one hole on their crank pullies to fit both the L98 and LT1. Don't know about Vortech or any other blower pulley manufactures.
Old Jan 22, 2004 | 08:29 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
AAAAAhhhhhhhh! thats it!
thanks.
so now all i have to do is get one ment for a LT1, and possibly slot one hole a lil bit.... i can do that with a hand drill....
i dont have a lathe, otherwise, i wouldnt have this problem at all.
Old Jan 22, 2004 | 02:11 PM
biggtime's Avatar
I have a eight rib laying around, let me know
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
MoJoe
Sep 15, 2015 12:50 AM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
