Nitrous Upgrade without Spending $$$
Old Jan 24, 2004 | 11:49 PM
casper8x's Avatar
Car: Black 1988 IROC-Z
Transmission: 700R4 soon to be TH400
Alright everyone here's the deal I currently have a N.O.S. 100-150 plate system on the IROC-Z. I'm building up a new nice and strong motor that I want to spray at least a 200 shot. But as all of us my money tree needs some miracle grow.
What I need to know is if I can modify my existing plate system to support 200 plus HP? Almost all the Plate EFI system are capped at 150 or so, yes I have seen the under injector system (I forget what they are named) but they are big bucks i.e. 1500 big ones.
I have seen a custom system with NOZZLES that may work.
I'm in the brain storming phase any input would be appreciated as long as it dollar conscious.
Old Jan 25, 2004 | 01:42 AM
JERRYWHO's Avatar
I have gone to 210 HP with my N.O.S. 5151 kit all you have to do is upgrade the nitrous solenoid to a cheater or more, install the proper jets and upgrade your fuel pump to one that will hold fuel pressure.
Jerry
Old Jan 25, 2004 | 03:54 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
I have alot of questions for you guys taht have the 5151 Nos kit on their TPI. If you could contact via Aim (HAMSPICED) or e-mail (Hamspiced@earthlink.net)
mostly if theres a part number for the Throttle body spacer, or questions about the actual installation.....
Old Jan 25, 2004 | 11:41 AM
casper8x's Avatar
Ok, sounds good, I was thinking along the same lines. I just wanted to see if anyone had done this before. I'm probably going to keep it at 200 so this shoudn't be a prob.
Linson
Oct 24, 2025 02:00 PM
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
