accel fuel injector users
Old Feb 25, 2004 | 06:48 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
from what I have seen on these boards (note have not seen proof) they seem to be know as bad injectors from day one or stop working all together while still fairly new. is any of this true?
Old Feb 25, 2004 | 07:14 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I've had mine for over one year with no problems.
Old Feb 25, 2004 | 07:35 PM
Engine: ls1, LB9
good, I am just wondering because I see them for sale alot and I need larger injectors to go with the s/c and I don't want to buy something that is junk
Old Mar 11, 2004 | 09:15 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
Mine are almost three years old and are working fine. I am very happy with them.
Old Mar 11, 2004 | 11:03 PM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
For some reason the Accel injectors would not start one of my engines in one occation. I was changing injectors and the high impedance Accel's injectors would not start the engine, still dont know why. The funny and sad thing is that I ended buying a set of Performace Ford injectors also high impedance and same size and the car runned perfectly. If you are looking for bigger injectors with stock ECM dont go any larger than 24. The stock ECM will work fine up to 24 sized injectors, any larger than that will cause you problems, it happened to me once and ended spending a thounsand of $ testing injectors.
bryan623
Mar 22, 2021 06:43 PM
tazs2000
Jul 15, 2017 08:44 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
