what fuel pump to use ?
Old Mar 24, 2004 | 07:31 PM
blkgta's Avatar
i have a third gen - 600 + horsepower with spray
400 on motor + 200 nos shot
383, alum heads
55# or 72# siemens injector ? not sure yet
i have a new stock fuel pump in the tank - 2000 miles
will that feed a inline pump (bosch) ?
or can i buy a powerful in the tank pump
& not run a inline pump ?
or do i need 2 pumps ?
any ideas - i am going to pull the tank this weekend
pump brand or ??
thanks
Old Mar 24, 2004 | 11:07 PM
biggtime's Avatar
I use the big aeromotive external on my stuff.
Old Mar 26, 2004 | 10:42 PM
Jack G Jr's Avatar
You can also check with racetronix.com he has an intank pump with hot wire kit.Heard alot of good things about it
Old Mar 27, 2004 | 07:30 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Walbro GSS340 in-tank. And if by some remote chance it's not enough, add a Kenne Bell Boost-a-Pump. Rich Krause at camaroz28.com uses this setup on his F1 procharged fourth-gen to the tune of 750+ hp.
Old Mar 27, 2004 | 10:18 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
I agree, dont take chances with not enough fuel. Sump the tank and run an external. I run an Aeromotive a1000 with -10 feed line from the tank all the way to the motor.
BTW I think you'll like the 55's better than the 72's with regards to driveability and they should support all the power you want. I had them the last two years and maxed them out at right around 650hp, but I only have 6 so with 8 they should flow enough fuel for 850+hp.
HTH,
Steve
Old Mar 27, 2004 | 04:02 PM
blkgta's Avatar
thanks for all the advice guys !
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
