Hey TTA guys.... plenum?????
Old Apr 21, 2004 | 07:25 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
A guy i work with drives an 87 GN. He heard about this thing called a plenum, which is some kind of plate that fits on his intake and smooths the air-flow and reduces lag... When i think of plenum i think of my TPI. He was explaining some plate with different slots and holes cut out... You guys ever hear of this mod???? Is it worth his money??
Old Apr 21, 2004 | 10:53 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
The RJC Power Plate. It goes BENEATH the plenum. I put one on my dads GN along with the Precision Plenum (according to the maker the best setup). Unfortunatly, I can't give any real results, as there have been a lot of problems with the car, not due to the plate. Most Buick guys like em, they're about $50 and while results vary, most have been able to get an extra lb or two of boost in before knock.
Old Apr 22, 2004 | 10:39 AM
Bill87GN's Avatar
Definitely worthwhile mod. For 50 bucks you can't go wrong and anything that evens out the airflow to all the cylinders, especially to those rear two.
http://www.rjcracing.com/RJC_Buick_P...wer_plate.html
Check out their other products too. Top notch quality and excellent service
Old May 10, 2004 | 06:03 PM
t-top89's Avatar
the PP is a very good mod because is distributes the air evenly.
Goes between upper( dog house ) and lower plenum.
All of my plugs burn even and the 02 #'s are the same. 93 pump gas after the install and I ran 18psi 0.0KR on street..... Strip... same set up I ran 12.91. @108 0.0kr bad short time of 1.99 and that was the first time out.
Thrasher 92, THDP,TA49, 50# inj., street tires,and restalled stock vert.
Good mod in my book
Bo
89 turbo trans am
Old May 16, 2004 | 05:46 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Yes it's worth it.
You gotta tune for the leanest cylinders. This kinda puts all the cylinders on the same playing field so to speak(for lack of a better term)
Old May 16, 2004 | 09:16 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
thanx for the tip.....
boy, am i thirsty for a frosty Samual jackson beer.
Old May 17, 2004 | 05:14 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
I also have one on my car and it seems to work well. And dont belive anybody that tries to tell you it's a restriction in airflow, the maker of the peice has gone 9.96@133 with it and I've personally gone 10.69@125.8 with it. I think it's one of the reasons I've been able to run so well on pumpgas too, at 19psi, nothing but 93 octane in the tank, and 0.0 knock I've gone 11.20@119 w/1.55 60ft and 11.22@120 w/1.58 60ft.
HTH,
Steve
tglennon11
Sep 23, 2015 05:30 PM
Jk_Under
Sep 8, 2015 08:13 AM
apie2546
Sep 5, 2015 07:40 PM
90formulaVortec
Sep 3, 2015 09:26 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
