Update on my 89 TT L98 IROC
Old May 30, 2004 | 12:13 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Unfortunately, we're still in the process of painting the car. Working on a custom hood right now with two air-craft style ducts in the front center (like on the front of a Dodge Viper, except x2). It also has a slight cowl induction look which follows the factory lines. Once thats done, the paint will spray. Anyway, this long delay has given me time to afford some larger turbos and some other mods.
I purchsed two T3/T4 hybrids to replace the smallish volvo turbos that were on.
Turbo Specs:
Turbine- Turbonetics T3 .63AR, Stage 3 Wheel- this was the biggest exhaust housing that would fit on my manifolds and not hit the valve covers.
Compressor- TO4E 57 trim wheel, .50AR
Ball bearing center sections
Also installed 1.6 ratio rocker arms and enlarged the pushrod slots for clearance. I think this should give a decent turbo cam. I measured roughly .460" lift with my dial indicator. Since it is the stock L98 cam, I believe the LSA will be in the range of 116 or 117 (I think the stock spec is 117, but I'm not sure).
I was also thinking of installing 30# injectors in place of my 24# units in currently. However, I'm questioning whether or not that is going to work since I am running a stock prom. What do you all think?
Here is another pic. It gets me excited every time I see the motor. I can't wait to put it back on the road!
Old May 30, 2004 | 03:36 PM
Steven89Iroc's Avatar
Good stuff.
I'd definately recommend getting bigger injectors for that much more airflow capability, it's the right way to do it. The FMU can only go so far before it starts becoming a problem IMO. See if you can find someone locally that will burn you custom chips, alot of people would be glad to. Otherwise, buy all the stuff you need and start learning to tune it yourself, I think that would give you more satisfaction.
lt500r55
Sep 1, 2021 01:30 PM
IROC315
Oct 27, 2015 09:57 AM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
mustangman65_79
Aug 11, 2015 03:17 PM
