Older Paxton Balldrive fluid change
Car: 1985 Z28
Transmission: 700-R4
I made an interesting discovery today, it is not plumbed into the tranny! There is NOT a drain plug anywhere, and I need to change the fluid asap. Anyone with any information please post, pm or email me asap please
I got a 500 mile road trip set up for tomarrow if I can get this darned fluid changed.
Cameron@ptsi.net
I got a 500 mile road trip set up for tomarrow if I can get this darned fluid changed.Cameron@ptsi.net
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
go to kragens look in the battery department on the wall and the part is called lynx L875c bulb battery filler it is red in color.
Cameron,
go to the local dollar store and get a turkey baster. The sn ball drive units use a turkey baster that has a tube attached to teh inside of the baster. The tube extends the reach of teh baster which allows you to remove all of the fluid. Don't freak out! So now, get some sort of metal tube or plastic tube that will fit inside the baster, then empty the oil out.
Now, IF and or when you need a rebuild, shoot me a pm. Right now is a busy time for me..going through a medical program at harborview...time is sparce for me...sleep too! I have rebuilt my sn2000 twice. Easy as pie! The sn units are self oiling units and you can purchase an oil cooler which is essential for extending the life of these chargers. I have heard the horror stories of the sn units, however, I ahve been lucky with mine! I was going to get a procharger, but i have had such good luck with mine, I decided to keep it. I do like the fact that it is mouse quiet! One other reason I don't want to spend another 3g's for a procharger. Dont' get me wrong, If I had to choose between teh two, procharger is the one I would pick! But since I have the sn2000 and I know how to work on them, I"m keeping it. I do have a repair manual for them too, so when that unit starts making a whistling noise, PM me. AND GET the oil cooler! call craig at paradise wheels, its about 300 bucks.
maroe624
Apr 16, 2017 08:29 AM
toronto formula
Nov 10, 2015 06:17 AM
Thornburg
Aug 25, 2015 01:46 AM
92camaroJoe
Aug 13, 2015 06:07 AM
