Any crate V8's suited for boost?
Old Oct 18, 2004 | 08:36 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Are there any companies out there making crate motors to handle boost? I want to eventually run about 10 lbs of boost and really would just like to buy a crate motor instead of having one built. At least for now.
Old Oct 18, 2004 | 09:20 AM
maroon91rs's Avatar
Car: 91 Camaro RS
Engine: L03 305 baby!!!
Transmission: stock 700r4
If there was a crate motor built to handle decent amounts of boost, I would think that it would be more expensive to buy that than just building your own. Unless youre strapped for resources to build a motor(ie garage, tools,ect), I would seriously looking into building your own to save a good chunk of change that can be put towards other things.
Old Oct 18, 2004 | 08:40 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
TTA 3.8 ? I know it can handle more than 10 psi JK
Old Oct 18, 2004 | 09:51 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
For a shortblock I am sure that you could talk with one of them that will change the pistons to forged dished ones so you could have the proper CR. The key would be picking corresponding heads. Look for one that has "options".
I woudln't be surprised if that isn't a regular request with so of the more special houses. The same requiremets go for supercharged solutions also.
Jason
Old Oct 19, 2004 | 12:36 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
through ebay you have acess to some very nice engine builder selling 350 with all forged asseblies in the same or lower price range than the crate motors come in.
Old Oct 20, 2004 | 01:15 AM
Russ-So Cal's Avatar
The Motown 454 small block crate motor is built with all forged pieces. It would just require them to build it with lower compression. I would think that it wouldn't be that difficult to order one with low compression for boost.
Street Lethal
Jul 22, 2022 04:32 PM
alan91z28
Aug 25, 2015 09:33 AM
Mailbox Hunter
Aug 30, 2013 10:26 PM
Ghigman3
Jan 9, 2004 12:31 AM
Gta-Paladin
Dec 10, 2001 06:54 AM
