305 Turbo
Old Nov 29, 2004 | 07:18 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
305 Turbo
I would like to know if this T0E417 turbo would be good for a very mild 305 turbo project. I believe its a Garret M24 with .50 A/R. Thanks for bearing with me i'm a turbo newbie! And i want to learn.
T0E4-50trim
Old Nov 30, 2004 | 10:37 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Not big enough, but I'd buy it off you for my 2.8. That's bigger (about 8-10lbs/min) than my 16G
Old Nov 30, 2004 | 10:38 AM
Doward's Avatar
Oh, and to give you an idea - my 16g runs 38lbs/min of air, and is too small for a 3.1L. 191ci. @ 7psi. That T04 50 trim would be better for my car, but still not quite big enough.
Serious about buying it off you, though, if you want.
Old Nov 30, 2004 | 12:06 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I don't actually have the turbo, sorry.
This turbo would go on a really mild stock 300 or so cid engine with a redline of (~3750 rpm). Stock the engine makes 110hp and 250tq. I'm not looking for more then 10psi boost.
So are these calcs correct:
CFM=Liters*rpm*VE*Pr/5660
Pr=(14.7+boost)/14.7
CFM=5*3500*65*1.7/5660=340
340/14.27=27.6 lb/min
So this turbo is just a little small?
Thanks this site has the best info.
Jake_92RS
Jan 28, 2020 10:37 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
tom1985
Apr 19, 2016 07:55 AM
makaveli09
Aug 12, 2015 09:07 PM
