Blown or just Blown Up?
Old Feb 26, 2005 | 12:13 AM
qwik86iroc's Avatar
Car: Guess!
Engine: 350 Stealth Ram, Supercharged
Transmission: 700R4 / 3.73
I have a Holley stealth ram, Accel 24lb injectors, crane cam, headers, bullet muffler, msd6al, 58mm throttle body, and a superchip, in a 350, with stock heads 72cc I believe, with a 373 gear in my 86 Iroc, and I'm about to install a Vortech Supercharger. I plan to run about 6 psi of boost. Is this possible with what I have or will I need more parts. I also have a Granatoli fuel pump which claims 67 GPH. The pump is a V-1 S Trim which we made a bracket for to fit my setup. Since there's no kit for 86. So will it work or do I need to spend more cash?
Old Feb 26, 2005 | 02:33 PM
Vader's Avatar
I'll slide this over to where you might get some help. Personally, I'm thinking that the 24# injectors may be a little smallish.
Old Feb 27, 2005 | 05:33 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i had 24 pounders in my car i had to retard the timing alot because of pinging found out the 24 where to small installed 30 pound svo problem gone.
Old Mar 1, 2005 | 07:37 PM
qwik86iroc's Avatar
Car: Guess!
How much psi were you pushing?
Old Mar 4, 2005 | 08:40 PM
qwik86iroc's Avatar
Car: Guess!
Nevermind
We got the charger all hooked up today, sorry I can't say the same for my tires. What a difference. I don't appear to be having any problems either. Fuels good, sparks good, and no pinging. No surges, and no broken parts. The bracket my mechanic made works beautifully. To look at the top side of the car you'd think it was a factory bracket. I'm still using my '86 accessories. minus an A/C compressor. Not sure of my boost yet but whatever it is, my 350 likes it. I'll have pics soon if you care, and hopefully some info on what PSI I've got. No FMU, No T-Rex, and no BTM. I know I'm happy.
Old Mar 7, 2005 | 02:17 PM
Lason's Avatar
Are you sure the fuel is good with 24's? Have you hooked it up to a wideband to make sure of that? Also how much boost do you have the charger pullied for? The reason I ask is becasue in my expirience working on stangs 24's are barely enough for 302 with low boost and no FMU. On a 350 I would assume 30 lb'rs would be better if not 36's, especially with the 58mm throttle body your using. Anyway just my $.02 and I could be wrong.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Jonas Earl
Sep 27, 2015 07:39 AM
383backinblack
Sep 25, 2015 11:31 AM
KCG
Sep 23, 2015 09:05 AM
corey8084
Sep 17, 2015 02:56 PM
