Fuel injection question
Old Mar 6, 2005 | 11:50 PM
jcaldwell's Avatar
I am gunna guess that most of ya'll started with a car that is already EFI , but I want to do a turbo project on a C3 Vette, all of which are carbereted. I have found some kits from edelbrock and holley just wondering if anyone knows for sure if one works better or not. Also on the holley site http://www.holley.com/HiOctn/ProdLin...PFI/MPFIS.html it "has" seperate kits for FI up at the top but none are shown in the lists. Will I need a special manifold for the project? Thanks.
Old Mar 7, 2005 | 02:12 PM
Lason's Avatar
Why not do a blow through turbo setup? If I were in your shoes that is DEFFINETLY the route I would go. Yeah everyone says carb's and turbos dont mix and bla bla bla, it B.S. Go to turbomustangs.com and tell them that and see what they tell you.
Old Mar 7, 2005 | 08:37 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
If I was in his shoes I'd laugh at this response, and pick up a victor EFI.
-- Joe
Old Mar 9, 2005 | 03:26 AM
83 Crossfire TA's Avatar
The ’82 vette came with FI
As far as blowthrough goes, it can be made to work very well performance wise, but it is somewhat limited in transient response since you basically tune the carb to work NA in the low ranges and the for full boost at WOT
WRT to efi systems, depending on what you're putting it on, swapping a factory efi setup is really no more difficult then going aftermarket.
Old Mar 9, 2005 | 09:38 AM
jcaldwell's Avatar
Yea but what from what I have read the cross fire system (Fuel injection on the '82's) is really crappy. So I would have to go aftermarket, unless does anyone know if the TBI or TPI set up from a 350 3rd gen would work on a C3?
Old Mar 9, 2005 | 09:41 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Honestly, if your looking to make power i'd look into a victor efi.
-- Joe
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
86Base
Aug 13, 2015 05:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
