Accel Shorty Header plugs?
Old May 12, 2005 | 08:57 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Are Accel header plugs cold enough? I think they are about 1 or 2 steps colder but I cant find anywhere to confirm.
anyone know?
When I put them in about a month ago I gapped them to .045...is that ok?
Old May 13, 2005 | 10:03 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I tried a set of those last year and had terrible luck with them. Kept fouling out very easily. My advice is to do what I ended up doing. Use Autolite plugs. They are the same length as the shorties and a whole lot cheaper. When using the Autolites you can cross referance the part numbers with AC delco at the part stores.
Old May 16, 2005 | 05:22 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
you wouldn't happen to have them part numbers handy for them plugs would you ?
Old May 16, 2005 | 07:24 PM
which plugs? the ones that I have?
If your talking about mine, they are the ACCEL Header Plugs
part# 8198 Plug # 574S
Old May 25, 2005 | 12:16 AM
CAH383's Avatar
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
I used them for about a month a couple years back and they fouled out very quickly. I would use the Autolites or something else like mentioned above.
Old May 25, 2005 | 12:47 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I didnt have much luck with them either, not to mention they're only slightly shorter than your average plug.
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Sep 8, 2015 03:38 PM
midge54
Sep 2, 2015 06:27 PM
LilHot
Aug 23, 2015 09:36 PM
mustangman65_79
Aug 7, 2015 09:55 PM
