Tapping fuel line for Nitrous install
Old Aug 13, 2005 | 10:38 PM
vwdave's Avatar
What is the best way to tap into the pressure side fuel line when installing nitrous? Links to products/information would be extremely helpful.
Old Aug 14, 2005 | 11:47 AM
vwdave's Avatar
Good thing I am not in a big rush for a answer. You would think with so many people with Nitrous on this forum, I would have had at least one answer by now.
Old Aug 14, 2005 | 05:38 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
https://www.thirdgen.org/newdesign/tech/ednitrous.shtml
Old Aug 14, 2005 | 05:46 PM
vwdave's Avatar
I knew that way already. I was wanting to tap the actual pressure line on the driver's side. I am trying to simplify the engine bay.
Old Aug 16, 2005 | 06:19 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
When I did mine, I went with braided fuel lines coming up from the chassis connections. I put a -6/-6/-4 T junction in there, then ran a -4an line to the fuel noid. Looks super clean, and was very simple. I also have a -4/-4-/-4 T, that I can put in, to connect my fuel pressure gauge with, so I can check fuel pressure with nitrous going.
Old Aug 16, 2005 | 06:31 AM
vwdave's Avatar
How does/did it seal? There are o-rings in there. Or is there special fittings to go onto those?
Old Aug 16, 2005 | 10:54 AM
Dewey316's Avatar
Car: 1990 Camaro RS
what do you mean?
I got the proper adaptors to attach an AN line to the fuel line fittings, and then into the stock (throttle body in my case, for TPI it would attache to the fuel rail), then the rest of it is a normal AN fittings. To attache the AN to the noid, you need the proper adaptor, if there isn't already an AN fitting there, my noids used 1/8 NPT, so there I used a NTP/AN adaptor.
Old Aug 16, 2005 | 06:38 PM
vwdave's Avatar
what do you mean?
Ok, what is the proper adaptors, thats why I am trying to ask. I already know how to run all the rest of that BS, just that one part is hanging me up badly.
Old Aug 17, 2005 | 06:26 AM
Dewey316's Avatar
Car: 1990 Camaro RS
I think that all the cars have the same hard lines. Your car is an orginal RS, so these should work.
You need 1 -6AN / 16mm x 1.5 O-ring and 1 -6AN 14mm x 1.5 O-ring
http://store.summitracing.com/defaul...tt=EAR-9894DBJ
http://store.summitracing.com/defaul...tt=EAR-9894DBH
(ingnore the pictures, the description says that it is a female adaptor.)
You will probably want some 90* hose ends for the lines, so that they angel back up coming off the hard lines, otherwise they are facing pretty much the front of the car.
Then for tee'ing off the that line, to the noid, you have a few options. You can find a -6/-6/-6 Tee, and use a reducer, to reduce it to a -4AN line. Or you could can try to find a -6/-6/-4 Tee (I don't have a part number handy.)
When I get home tonight, I'll take some pictures of my plumbing, so you can get a little better idea at how it is run.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Firechicken86
Aug 12, 2015 10:07 PM
