Super, Turbo , nitrious, or N/A
Old Aug 24, 2005 | 06:22 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
I am going to be building up a 383 small block in my spare time
and am wondering what would be a sweet set up, I was thinking
on doing a N/a set up with a monster cam and just running the
thing through the roof, or a power adder motor, with a S/C or
turbo or maybe even nitrious (sp?) What would be a cool set up
that i can have fun with, its not a daily driven car and i want
some power, gas is not the biggest of problems but i dont want
to be paying out my *** for fuel. sooo what would you guys
recomend for a sweet street set up and a good track performer,
also what would be an easy thing to keep up with on keeping
everything is right order, an kits that i should look at? thanks
Colt
Old Aug 24, 2005 | 06:39 PM
Fastkingcab's Avatar
Car: 87 IROC-Z
Keep it simple go N/A Then spray the **** out of it
but there isn't much cooler than a Turbo or two
Old Aug 26, 2005 | 08:41 AM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
my vote it for the turbo, they get better gas mileage when you drive it easy and they just sound so dam cool.....
Old Aug 26, 2005 | 10:24 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
My vote is for a n/a motor and spray it with a NX Wet kit. That's exactly what I did with my 383 build-up!
My best n/a time in my sig, so far, and I will be using the nitrous for the first time this weekend.
Old Aug 26, 2005 | 02:58 PM
79vette's Avatar
Car: 1979 Corvette
Engine: 355, TFS heads, comp 270H cam, 10.5 comp.
Transmission: 700r4/ 3:55 posi/ 2500 stall
I am doing homework for a 383 with a Procharger P-1sc on it. they are simpler to set up and dosn't make your engine compartment so hot and gives similar performance as a turbo. That and its going to be a blow thru carb set up so I dont need to have all the add expence of messing with EFI. It should make my Vette move pretty good.
no green
Jan 9, 2016 09:22 PM
bjpotter
Oct 4, 2015 07:48 PM
Zell1luk
Sep 29, 2015 10:36 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
