question
Old Aug 30, 2005 | 05:15 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
question
Can 30 pound injectors support a 355 superchargerd because i am getting halfthrottle ping still,i have timming set at 2 degrees i have colder sparkplugs also had a custom chip but not working right and i have the chip burnning soft wear tuner pro etc but not getting it.fuel is set at 40 psi help.does egr still work under boost.
Old Aug 30, 2005 | 11:13 PM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
your probably running out of fuel, 30lb injectors at about 80% duty cycle can only support about 400hp look here to figure out what size you need http://www.iroczone.com/calcs/injectorsize.htm or this one http://not2fast.com/turbo/glossary/turbo_calc.shtml#wi
Old Aug 31, 2005 | 12:45 AM
antoine's Avatar
thanks for the info will look into it.also what about if i use a fmu 6:1 will that work.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
