Dry N2o questions
Old Sep 12, 2005 | 12:37 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Dry N2o questions
I have a dry zex nitrous kit
I have run with a 75hp shot and found that the odd run it will not run right. It will "puke" (the motor loses power), then the fuel pressure will spike up. I am not sure if the pressure goes up 1st or the car runs like crap then the fuel pres. spikes.
Do anyone think that my injectors are static locking?
The only thing I did differntly from last year(when it was working right) was I put on 1.6 roller rockers.
My best run with the 75hp shot is 8.66@78(1/8th)
My best run with the 50hp shot is 8.71@80(1/8th)
Oh, btw, the motor doesn't puke with the 50hp shot?
I am running 15 degrees timing and 45psi fuel pressure.
Any thoughts??
Old Sep 13, 2005 | 07:41 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
somebody has got to have a dry kit?
Old Sep 13, 2005 | 07:44 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Another reason why I don't like dry shots.
I would suspect the injectors, but it'll be hard to check them w/o some type of scan tool where you can see the duty cycle. Might want to try checking vacuum lines, elec. connections, and fuel filter first. How do the plugs look? Do you have a better explination of what the car does when it 'pukes' as you call it?
Old Sep 13, 2005 | 09:07 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
When the car pukes, it still accelerates but isn't full out.
You can see the front of the car come down when it pukes
It's like a car driving then rapidly pulling the choke on.
Old Sep 13, 2005 | 11:05 PM
83 Crossfire TA's Avatar
You’re not going to see the injectors locking on a scan tool… the tool will report what the ecm tells the injectors to do, but if they’re stuck open or closed the ECM won’t know.
That being said, I wouldn’t be at all surprised if the injectors are locking with the pressure spike of a dry kit, or if you’re getting too much fuel causing the engine to bog down some but there isn’t really a good way of finding out without either WBO2, just swapping injectors and trying it or some educated guessing by someone that has seen it before.
Plugs would give you a good impression of what the problem is, but you would have to shut down _right_ after it does it and pull a plug right there to get an accurate reading, even driving a sort distance to get someplace comfortable will mess up what you see on the plugs.
Old Sep 16, 2005 | 08:20 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
anyone have a dry kit?
Old Sep 17, 2005 | 02:07 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
TraviZ had the zex drykit he killed the stock injectors from the fuel pressure spike he replaced them with ford svo 24# and never had a problem with it
theshackle
Mar 5, 2017 06:37 PM
Scamo-2.8
May 20, 2016 07:01 PM
TheExaminer
Aug 26, 2015 04:59 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
redmaroz
Aug 16, 2015 11:40 PM
