Turbo or s/c with a carb, any pics and info
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
Well im doing an engine swap and way more hp soon and need to decide the route im goin , high compression 10.25 high for the street , or go with 8.25-8.75 and have a power adder. I dont want fuel injection so whats my options as far as where to buy a sc or turbo and the carb hat and all that stuff. Im pretty neive with power adders for carbs.
I run 9 to 1 comp with a blow thru s/c. ATI-vortech make bolt on kits. Mine is an ATI D1sc 12 rib. Hat is Extreme velocity hat with o-ring seal from superior airflow. Don't forget fuel system- must be upgraded for blow thru set up.
Check turbomustangs.com use the search button
Matt
Matt
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
if you have questions about a blow-thru turbo setup check out turbomustangs.com, if you have any questions about that type of thing they can answer it.
good luck
good luck
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
what do you mean the fuel system mjst be upgraded, my car has fuel injection now , dont i have enough fuel pressure and volume. You got any pics of the setup on the car currently .
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
