NOS & 5 speed
Old Oct 26, 2005 | 07:24 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
NOS & 5 speed
I can't get the picture of a big red purge cloud comming from my black bird... so a few questions...
I'm well versed in NOS theory, but have not yet applied it to my car... my question...
I have a 5 speed.... when I go to shift, of course I release the throttle partly, so NOS is shut off cuz it's only on at WOT, once I shift and punch the throttle, it should turn on... is this alot of stress for my 305, turning on & off between shifts?
Should I get a progressive controller, or will it be fine with out it...
Rafael
Old Oct 27, 2005 | 09:28 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
That's kind of an open ended question. What do you want. Reliability from a sprayed 305? Your asking a lot. How much will you spray? How do you shift? Smooth? How is the suspension? Do you chirp the tires when shifting?
A controller that meters the n2o w/ RPM is what your looking for. Something that resets when you lift. But you won't get all you can from it set up that way.
Old Oct 27, 2005 | 10:05 AM
luvofjah's Avatar
The car is not a daily driver, & reliability, if setup properly, shouldn't be an issue....
100 hp shot....
Car has mods, suspension, ignition, etc...
I understand what the progressive controller does, but how would the engine handle a shot for a few seconds, off, on, off, on, etc...
I'm sure I'm not the only person with a 5 speed....
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
Sep 23, 2015 06:50 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
