Cracked Head????
Old Nov 2, 2005 | 06:58 PM
Blownstealthram's Avatar
Car: 1986 IROC Z
Engine: 357, Holley Stealthram, Paxton SN93 Supercharger, Commander 950 ECU
Transmission: Borg Warner T-56 with Spec Stage 3 Clutch
Cracked Head????
I have a 357 with about 9.8.1 compression running a PAXTON SN-93 and it makes about 6 pounds of boost, I have just recently put it on my car and the car was warming up in my driveway. I rev it a few times checking the basemap on my laptop. I see white smoke coming out of the tailpipes. I figure i blew a head gasket. In fact i cracked a head. I had overheated the car before but i never saw white smoke to make believe i blew a head gasket. I take the heads off and one is cracked. I had the motor running rich so i doubt it detotnated. I was wondering if anyone else running boost has cracked a head especially without any engine load. Also has anyone cracked a head overheating? The heads are L98 heads all done up.
Old Nov 2, 2005 | 10:04 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
my brother's 350 nova was running on 7 cylinders after an overheat on the highway. He tried to run the motor into the ground before he put in a 396. that thing ran strong for like six months (on 7) without a problem and he decided to stay with the small block so we took it apart to see what was wrong. the headgasket was completly gone between the 3 and 5 cylinders, but some how that managed to make the #3 cylinder run stronger to make up for the lack of #5. I was cleaning up the heads later to put them back on the engine and there was a chunk of iron almost completly broken off the driver head right where the head gasket blew. I think it is pretty common to crack a head when you over heat. Its pretty common to blow a head gasket
Old Nov 2, 2005 | 10:14 PM
Car: 1986 IROC Z
nevermind i got it pressure tested it wasn't a crack it was a little galge in it. I guess i lucked out
Old Nov 3, 2005 | 01:14 PM
Oh, and after we saw the crack on the head we checked out the block and it was cracked too, right between the #3 and #5 cylinders. he had it fixed at the machine shop.
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
theshackle
Mar 5, 2017 06:37 PM
michealleger
Aug 26, 2015 03:29 PM
