extra fuel for boosted tpi
Old Nov 6, 2005 | 12:44 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
hi all, i just wanted to find out what you boosted tpi guys (and maybe some chicks) are doing for extra fuel on your tpi's, i have a 5L with a maf, my plan was to install a 255lph pump and a riseing rate fpr with a 12:1 disc. any other ideas?
Old Nov 6, 2005 | 04:53 PM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Well apart from bigger injectors and PROM buring thats about it. Im using the Bosche 044 pump and Malpasi Rising rate reg.
Old Nov 6, 2005 | 05:11 PM
high c's Avatar
Car: 86 iroc
thanks for the reply!
how much boost are you running? and what disk is your fmu?
Old Nov 6, 2005 | 08:02 PM
only 3 psi right now, but good for 6. Just need a decent boost control setup.
Dont know the ratio on the malpasi as i bought it second hand and it has nothing writen on it. Works tho.
Old Nov 6, 2005 | 10:50 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I am running 7psi right now, but going to 5psi. I tried using the 1992 730 MAP ECM with stock fuel pressure and 42#/hr Ford injectors. I didn't like it at all, but I only messed with tuning it for one day. I swapped to the Syclone code today and have A LOT of tuning to do. It runs great at full throttle, but bad every where else. You must be able to edit & burn PROMS with or without an FMU.
J
Old Nov 9, 2005 | 05:18 PM
high c's Avatar
Car: 86 iroc
most deff thanks for the replys i think im going to go with the fmu, until the ol' 305 is done in and then i might go on to better
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
