where to find intercoolers?
Old Dec 14, 2005 | 10:03 PM
pskel350's Avatar
just starting looking at a TT setup for my ls1. searched some and couldnt find intercooler like i want.
looking for dual inlets, and single outlet. probably 2.5 in, and 4 inch out.
does any company make something like this, or will this have to be custom made?
Old Dec 14, 2005 | 11:13 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I would just search ebay
Old Dec 14, 2005 | 11:49 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I found two Volvo intercoolers at the junkyard.
Old Dec 15, 2005 | 01:08 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Got a pic of those Volvo intercoolers?
Old Dec 17, 2005 | 08:57 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Here is one picture. Let me know if you are insterested in some exact dimensions or what the ICs look like inside without the end tanks. I can take pics of whatever you would like to see for the Volvo ICs.
Old Dec 17, 2005 | 12:07 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
something like this?
Old Dec 17, 2005 | 06:20 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
try and look oversea's for intercoolers for Skylines. ive seen a bunch of skylines still running the twin turbo set up and they have 2 inlet pipes and 1 outlet pipe. that might be your best bet as far as what your looking for, not sure about the exzact sizes but it will get you close.
Old Dec 17, 2005 | 10:26 PM
TA88GTA's Avatar
Sounds like the cooler i just orderd up. Try bell intercoolers they custom make whatever you need its not cheap though, mine cost me an arm and a leg.
www.bellintercoolers.com
Old Dec 17, 2005 | 11:36 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Nah, that doesn't look all that good for the setup I am doing. Maybe be fine for other stuff though.
The dual Volvo ICs I am using are for a 305ci. The two inlet pipes are 2.5 inch and the outlet is 3". I am feeding it like the pic you posted with two 2.5" pipes on one side and the Volvo ICs are a lot bigger than the pic.
The dual Volvo IC will be about 24"x17"x3" but without the strange dual pipes in the pic. I guess they did that because of the bad space-limited? end tanks. If the end tanks were better then only one pipe would be needed on the dual side.
I noticed then link was to ssautochrome........figures they would sell junk like that.
Old Dec 17, 2005 | 11:44 PM
junkcltr's Avatar
Engine: 3xx ci tubo
As in Corky Bell? Yeah, they have nice stuff. Expensive but worth it....not that I could afford one. I use their dimensions to get a (very) rough idea of what JY intercoolers would flow for the bar & plate ones.
Old Dec 18, 2005 | 11:54 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
heres a couple intercoolers i found on ebay. Here's for twin turbo camaro/mustang set up
another one
Old Dec 18, 2005 | 02:31 PM
1bdbrd's Avatar
Car: 1991 Trans Am
just have one custom fabbed. buy whatever IC core you want and send it to a reputable shop and have them weld on the end tanks. maybe try dropping the guys a line at www.houseofboost.com and see what they can fab up. they just did a custom twin turbo FMIC for a local 1000 ALL wheel hp skyline. so there work speaks for themselves.
Old Dec 18, 2005 | 03:44 PM
TA88GTA's Avatar
another one
I was also looking in to that company but they but they never returned any one of my 3 emails so i ended up going with Bell.
Old Dec 20, 2005 | 07:54 PM
pskel350's Avatar
looking for something like this.
i've searched forever and cant seem to find anything where to buy one like it. if i have to have one made thats okay, just would rather be able to order one pre-fabbed.
Old Dec 20, 2005 | 08:59 PM
1bdbrd's Avatar
Car: 1991 Trans Am
like i said, www.houseofboost.com
like i said, their work is IMO top notch and they WILL be getting some business from me in the near future.
Old Dec 20, 2005 | 09:03 PM
pskel350's Avatar
i can have one made at one of the numerous custom shops around me....just would rather have one to buy pre-made
Old Dec 20, 2005 | 10:15 PM
junkcltr's Avatar
Engine: 3xx ci tubo
That looks OK. Kind of square though. Wouln't you want something with end tanks that are more round.
From what I have read, the driver's side might get a little circular flow. I would think that a venturi effect would occur. Not sure what really happens.
Old Dec 20, 2005 | 10:22 PM
pskel350's Avatar
lol wish i knew more about them. thats one of the reasons i want a premade IC. that TA has gone high 8's, so dont think the IC is that bad of a design i guess
Old Dec 20, 2005 | 10:58 PM
junkcltr's Avatar
Engine: 3xx ci tubo
It is not bad, but could be better.
Old Jan 4, 2006 | 04:06 PM
putt-putt's Avatar
Car: 87z28 convt
try to look at ford powerstroke intercooler from their desile trucks, i know a few people using them on grand nationals
Old Jan 4, 2006 | 05:14 PM
junkcltr's Avatar
Engine: 3xx ci tubo
That IC in the pic is a better IC than a powerstroke IC.
It would take a lot of powerstroke IC cutting to get it to fit in a Camaro. Would probably be better off cutting it in halfway and welding it in parallel. Lots of work & dollars.
The GNs have a giant square nose....decent powerstroke IC fit.
Old Jan 5, 2006 | 02:13 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
I don't like it that much ... I think the tanks uses way too much of the available frontal area. It probably flows great from turbos to engine with minimal pressure drop ... but I don't think that it flows enough 'cooling' ambient air, and that is what acutullay removes heat from the charge air.
Old Jan 5, 2006 | 08:20 AM
junkcltr's Avatar
Engine: 3xx ci tubo
You will find that most IC builders & flow researchers have found that most of the cooling is done in the first 6 inchs of the tube. You want a thick IC with max. surface area minimizing the length the air flows through.
Old Jan 5, 2006 | 09:04 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
It is quite simple ... You want as much heat trasfer as possible.
You get the most heat trasfer where you have the biggest temperature differance between the inside and outsife of the core.
Look at the picture, In each radiator segment you have a good and a bad corner, the rest is in between.
The 'perfect' core dimensions depends on the flow velocity in each direction.
If the outside air flow velocity is too slow ... then the outside air will heat up shortly after entering the core. In that case a thicker core will not do you any good. In the picture only the lower part of the core will be active. In the upper part uncooled air goes straight thru without any cooling.
If the outside air flow velocity much higher than the chagre flow, then only the left part of the core will be active.
In a 'lab' you will find that 'square' core segments will work best if you have the same flow velocity in both directions.
In a car, especially at lower speeds, the charge flow velocity will be higher than the cooling air velocity. Then you need a thinner core with a larger frontal area. That way you get more cooling air volume thru the core to compensate for the lower velocity.
Breazlan
Sep 25, 2015 11:20 AM
Ranbo108
Sep 9, 2015 12:20 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
rjcme
Sep 5, 2015 01:23 PM
